Andrew Br
Still part of the team !
- Chorlton Cum Hardy
Also posted on yACF.
We missed the 2020 ride (for reasons........) but we're running it again this year.
The previous thread on CycleChat is here:- https://www.cyclechat.net/threads/manchester-blackpool-7th-june-2019.248841/
The travel info from the thread is still relevant:-
"You'll need to get to either of Manchester's main stations (Piccadilly or Victoria) in time to ride to Victoria Station for a midnight departure to Blackpool.
Most trains back to home depart from Blackpool North station. There is a direct Avanti service to London Euston and Northern Rail run direct to Manchester. Other destinations are (probably) best served by travelling to Preston and changing there.
You must have bike reservations for Avanti and Trans Pennine Express. Northern don't care as long as you're not creating too much of an obstruction. If you're going to use another train co. please check their bike policy."
As is the route info:-
"It's hilly but most of the hills are long and not too steep although there are exceptions to this. It also means that the descents are the type where you can just let the bike go.
This year I'm going to cut out some of last year's gravel section as we exit Manchester; we'll use the best surfaced section of last year's route before we climb to Prestwich. It'll mean we have an extra climb but it'll keep us off potentially busy main roads and we do all the initial ascending in one go. The main road goes up and down several times.
The mid-way stop is at a 24 hour BP Garage on the outskirts of Blackburn. It has a shop (sandwiches, chocolate bars, fruit etc) and a coffee machine.
The final part of the ride takes us down Blackpool Prom to the Tower and drinks*. Taking the line of least resistance, it may well be a Wetherspoon's but I'm going to try very hard to find an alternative.
Whatever I come up with, it'll be a few minutes ride from Blackpool North.
A few final things to consider about the route; it's in the North and it goes up high on to the moors so there is the possibility of weather and not the good kind. We've had most things on previous rides including, briefly, snow. It's also been glorious all night......
We go through some remote areas so a bike failure could mean a long walk and/or an expensive taxi ride.
There tends to be a small group on this ride so everyone gets to know everyone else; we suffer and enjoy together.
Finally, we'll have a brief stop in Bury to remember jogler/Alan S.
I'll bring flowers."
What has changed is that I'll need to find another place for breakfast in Fleetwood since Frankie's and Bonnie's cafe has closed. IIRC, we got to Fleetwood just before 08.00. If anyone with local knowledge has any recommendations then please let me know.
I also need to check that the restaurant at Blackburn McDonald's is 24 hour and not just the drive through. Update: only the drive through is 24hr so we're going to a 24hr BP garage just around the corner (see above).
As for drinks in Blackpool after the ride I'll try to find somewhere with outdoor seating since I still don't fancy sitting indoors with loads ofpiss-heads slightly inebriated people. Again IIRC, we got to Blackpool at just before 10.00.
Admin:-
Read this:- https://www.fnrttc.org.uk/manchester-to-blackpool-3-september It contains the registration form.
If this is your 1st Friday's ride, you don't need to be a member of The Fridays (there's a "try before you buy" option) but you'll need to pay £2 in advance for the insurance.
Other stuff:-
As I've mentioned above, we often get weather on the ride as evidenced by this video (courtesy of Josh, one of the Chorlton(CH) massive):-
View: https://www.youtube.com/watch?v=V-FtxXkm7qg
Surprisingly, Josh is still talking to me. Whether he shows up for this year's ride is another matter...........
Also, as I've said in the past, depending on numbers and if the tides are favourable, we'll take the ferry across from Knott End to Fleetwood. If it's not running or we're too big a group, we'll follow the "standard" route into Fleetwood.
Finally, the Strava for 2020:- https://www.strava.com/activities/2434201682 and the yACF thread for 2019:- https://yacf.co.uk/forum/index.php?topic=111883.msg2391393#msg2391393
If you've got any questions please just ask.
I've just realised that Avanti have taken over WCML trains from Virgin so I've corrected it above.
Admin:-
Other stuff:-
