Magic Shine Allty - spare mount
Jenkins
Felixstowe
The description indicates that it is Garmin compatable, so why not look for some Garmin quarter turn mounts on Ebay as that's what it look like to me?
Replacement Garmin handlebar mount for Allty series bike lights, hard plastic mount base attached with silicone strap, compatible with most Garmin devices, lights, speedometers, cellphones with adapters etc. Ideally used with moderate to light weight devices.
Twilkes
Twilkes
If a Garmin mount is a circle about the size of a 10p coin which locks/unlocks every 90 degrees, then yes that's the same, cheers.
In fact the out-front Garmin mounts look really useful, would stop the beam getting blocked either side by the hoods.
Twilkes
Twilkes
Hi @Twilkes,
Did you try the Garmin mount? Did it work?
I did, an out front style Garmin mount from ebay, and it does fit. It only rotates one way, whereas the previous one could be rotated either way to fit or remove the light, but it works.
I couldn't find a mount where the light fitted right over the handlebar though, only the out front ones which extended forwards a couple of inches or more.
