M6 x 19 bolt (Shimano)
PaulSecteur
No longer a Specialized fanboy
Hi,
A few days ago i was Investigating a "clicky" bottom bracket on a friends bike. I have replaced that as it was old and they had already brought a new one, but when coming to replace the non drive side crank I found that whoever had looked at it before had rounded the head, just enough so I cant get it to tighten enough... Just on one bolt
Its item 3 on this diagram...
http://techdocs.shimano.com/media/t...FC/EV-FC-4503-2594D_v1_m56577569830707832.pdf
Anyone got one to spare? I will cover postage with paypal.
Or failing that could I use a 20mm one? (I can get them from screw fix, but not sure if 20mm would be too long)
gbb
Peterborough
Assuming its a standard cap head screw, 19mm (as you know) is non standard.
1mm may or may not make any difference, if its a hole all the way though the crank, it wont (i assume) make any difference.
If its a blind hole, put something down it and measure how deep it is. If its a few more mm than 20mm, you'll be ok with a 20.
If there's not enough depth, look at the washer, if its a pretty standard type, add one washer, that'll effectively make a 20mm long screw..19mm.
stephec
Bolton
I could possibly get you a 20mm, but I'm not back in work until the 3rd Jan to check.
If you're not sorted by then let me know. :smile:
gaz
Cycle Camera TV
South Croydon
I have some M6 x16mm on my desk. with a hex head. Let me know if you want one.
EDIT:
I see you need a 19mm one, mine is probably too short.
ray c. flagg
Do you still need this... back in work today and have a selection stainless/high tensile cap head (let me know what you need) will cut it to suit if required? Do you need the spring washer as well..
