Anthony.R.Brown
Modern Technology,Aerodynamic Carbon Frames,Tri Bars,Carbon Disk Wheels,Tri Disk Front Wheels,Aerodynamic Helmet.
Below is The Cycling TT Modern Technology Advantage Formula... {MTAF}
A = Based on (Chris Boardman using a {MTAF} Track bike with a distance of 56.375 km)
B = and (Chris Boardman using a Normal Track bike with a distance of 49.441 km)
C = The Advantage difference in Km
D : 1 Hour/60 Minutes
E : The Advantage in Minutes
(A : 56.375 km) - (B : 49.441 km) = (C : 6.934 km)
(D : 60) / (C : 6.934 km) = (E : 8.65301413326)
Then...
(E : 8.65301413326) / (D : 60) = 0.144216902221 (for every Minute a rider,rides using a {MTAF} bike
Example if a rider rides for 60 Minutes then we calculate...
60 x 0.144216902221 = 8.65301413326 Minutes Advantage.
Below are the current Records held by M.Bialoblocki
10 Miles - 2016 M.Bialoblocki One Pro Cycling Ltd 16.35
15 Miles - 2019 M.Bialoblocki NOPINZ0 26.35
25 Miles - 2018 M.Bialoblocki NOPINZ 42.58
50 Miles - 2018 M.Bialoblocki NOPINZ 1:30.31
100 Miles - 2019 M.Bialoblocki NOPINZ 3:13.37
Then apply the {MTAF} to each time...
10 Miles - (16.35) x 0.144216902221 = 2.3579463513 Advantage
(16.35) + 2.3579463513 = 18.7079463513 (18.29) True time.
15 Miles - (26.35) x 0.144216902221 = 3.8001153735 Advantage
(26.35) + 3.8001153735 = 30.1501153735 (30.15) True time.
25 Miles - (42.58) x 0.144216902221 = 6.14075569653 Advantage
(42.58) + 6.14075569653 = 48.7207556965 (48.27) True time.
50 Miles - (1:30.31) x 0.144216902221 = 13.0242284395 Advantage
(1:30.31) + 13.0242284395 = 1.43.3342284395 (1.43.33) True time.
100 Miles - (3:13.37) x 0.144216902221 = 27.8872223823 Advantage
(3:13.37) + 27.8872223823 = 3.41.2572223823 ( 3.41.25) True time.
Below is M.Bialoblocki's current TT Records Average...
Total = 368.96 / 5 = (73.792) Minutes
Below is M.Bialoblocki's {MTAF} TT Records Average...
Total = 421.29 / 5 = (84.258) Minutes
(84.258) - (73.792) = 10.466 Minutes
Below is a photo of M.Bialoblocki using all the Modern Technology.
Anthony.R.Brown 09/03/2021
Former Chelmer CC
Then...
Former Chelmer CC
