Lubrication on new parts?
ren531
Lancaster uk
Having just built up a new bike with new pedals axles etc what is the general concensus on the factory applied grease on moving parts is it worth opening them up to see/apply more, asking because I have just removed the dust caps from the pedals and there seems very little grease in there at all.
ianrauk
Tattooed Beat Messiah
Rides Ti2
Yep, worth the bother in my humble opinion and experience.
Shimano hubs for example are terrible for a lack of factory applied grease.
sleuthey
I ride in all weathers so I grease the BB threads to prevent them seizing. What I don’t grease or lube when new is cables - clean n dry is my approach otherwise it attracts muck.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Haven’t done it on pedals, but yes on wheel hubs etc. I also grease non moving bolts to stop them seizing. Every bolt gets undone and regreased once a year, hubs inspected etc. Make sure you’ve greased the pedal threads as well. You don’t want those seizing.
Petrichorwheels
agreed, definitely on hubs - god knows what shimano (who I generally think highly of) are up to - I know we are talking massive volumes so their savings must add up, but still.
Any new hub of mine is taken apart - including on hand-built wheels, as the wheel builders are of course using off-the-shelf hubs - wouldn't expect them to take them apart.
I also take apart and check new headsets.
also a good idea with pedals, though sometimes takes me a while to get round to.
ren531
ren531
Lancaster uk
Yes I was using lube as a generalised meaning, its really grease on any bearing surfaces, but having had a better look everything bar the pedal axles are sealed bearings anyway.
