lubed up!!!
carrera25
can't get my trousers past my huge thighs!!
hey there was looking to put some axel grease on my bike to keep the chain etc. in good working order and wondering if good old carlube ML-2 general purpose would be ideal??
I did have GT 85 that quite frankly was useless.....washed off everyday in the Scottish weather so would like to know if this would do the trick!! cheers guys
young Ed
not familiar with that particular oil but if it is fairly thinish then yes
i among many use chainsaw chain oil and the mickling technique
link to mickling coming soon
Cheers Ed
Cubist
Still wavin'
Ovver 'thill
No. It'll attract all manner of grit and form a grinding compound over your chain, shortening its life and wrecking your drivetrain, not to mention making everything unimaginably filthy. Spend a couple of quid on a proprietary chain lube, and learn the "mickle method" of chain cleaning/lubing.
C
carrera25
Cheers Ed
no it's anything but thin....quite thick and heavy by the look of things......it's car axel grease!!! the GT 85 was thin almost liquid spray that had a PTFE laced through it but really was useless.....sprayed the bike everyday and got a new chain and still got rusty!!
C
carrera25
good thing I asked you guys first then isn't it!!! the bike is brand new....still has a tackiness to the chain etc so not urgent but thinking of getting something on it that will keep everything good long term as I want to look after the bike a little better than my last one!
Cubist
Still wavin'
Ovver 'thill
The coating on the chain will last a few miles, but eventually will wear off. If you like the chain to look clean and run smooth get one of the dry lube types. It'll need replacing frequently, but rewards with a clean and grit free effect.
