Lower back pain
Yellow Fang
Reading
When I'm out cycling for quite a long time, say over thirty miles, my lower back tends to start hurting. It's nearly always on the left hand side of my lower back. Does anyone know what might be the cause and how to improve it?
mcd
I had a similar sounding problem with my back. Got it looked at, and the verdict was something to do with facet joints. The bit that hurts is the muscles around one of the vertebrae stiffening up to protect the joint. Or something like that.
I found that anti-inflammatories, a bit of stretching, walking, swimming & rock climbing (badly) all helped loosen the sore area of my back which stopped it hurting. As for cycling, I used it as an excuse to get a recumbent. No more problems with my back when I cycle - but now I've got to something about the silly grin. :smile:
Could be numerous things: As MCD says, get it looked at. Find a good Osteopath to sort out the joints, then a physio to sort out the muscles or again, as MCD says, some stretching and other excercise can help.
Nothing worse than niggling back pain. Took me about three years to sort mine out. One good Osteopath was what finally did it, combined with regular excercise and stretching/tai chi - don't ignore it!
longers
Without recourse to practitioners I have got rid of lower back pain for myself by inverting the stem*. It would only kick in after 50 miles or so and the more hilly the ride the worse it was but my riding position was not upright enough on longer rides.
This may not work for you but only my personal experience.
*This was the only bike in the last ten years I haven't done this on and the only bike that's given me the lower back pain. Not any more though.
Yellow Fang
Yellow Fang
Reading
No, I was out on a 50 mile training ride with my tri club. I only tend to get it when cycling quite long distances on my road bike. I wondered whether the frame was too big or something.
Steve Austin
The Marmalade Kid
Mlehworld
it could very well be muscular. Yoga, pliates etc could work but then so could some good old fashioned sit-ups.
Of course i'm suggesting stretching. I reckon it works. some don't.
ASC1951
Yorkshire
This might be stating the blindingly obvious, Yellow Fang, but do make sure that your bike is correctly set up for you - size, reach, posture etc. - before you invest in physios and osteopaths. All the exercises in the world aren't going to help if you have the bars too low or the stem too long.
There are lots of websites with this info, or you could splash out on a professional bike fitting for the cost of a couple of physio sessions.
Fab Foodie
Kirton, Devon.
Agreed.
Also, make sure lower back is kept warm. Spin the pedals rather than grind a high gear. Get a larger saddle that allows you to move around on it rather than rigidly fixed in one position, Fizik Arione or my unfasionable (on a road-bike) Brooks B17 are long and allow much more movement to help the back muscles.
But most of all, get your positioning right relative to the pedals first and then adjust the bars to fit you.
There is no one best riding position IMO. The position that makes me go fastest over a 10 mile TT or club night is not the same position on the bike I'd use for a 100 miler.
Stretch hamstrings regularly.
Tynan
e4
had a spell of this recently, whacked the seat up quite a bit higher and it vanished
nom de plum
wilmslow ches.
orrrr...
it might just be your general core fitness
I used to get very painful lower back ache a few years ago, especially when climbing steep hills. The more I practiced hills the less the pain. I also swim and do a bit in the gym... I don't get it any more
Steve
yello
I'm hoping that's my problem.
I did a brisk-ish (for me!) hilly 50km yesterday and my back was aching like buggery at around 30km. This on a bike set up for me (ok, 3 years ago!) and that I have ridden for literally thousands of miles without pain. So I got off, and used my banana break as an excuse to stretch a bit. The rest of the ride was flatter and I had no further pain though it remained niggling.
Still niggling today so I'm staying off the bike to rest it (and watching the Giro on the box :becool: ). I'm hoping it's just my lack of core strength and nothing else.
