annirak
- Cambridge, UK
I'm continuing on my quest for a low maintenance commuter.
To summarize,
What I will use it for:
What I want:
If I'm going to build it myself, then I need to find a frame. So far, the best contender seems to be the Specialized AWOL frameset, though I don't like steel from a maintenance perspective--having to be always on the lookout for rust doesn't sit well with low maintenance, but I'm willing to try. If not the AWOL, then I really like the Paragon Machine Works rocker dropouts. They seem well-suited to this sort of use. I wonder if a custom titanium frame would be the right choice.
The trailer probably rules out carbon. Aluminum might be an option, but there is still the question of metal fatigue with the higher load that comes with a trailer
For a complete bike, I'd like it to cost less than £1500. For a frame, less than £750.
I'd be appreciative of any suggestions for frame or complete bike that matches those specs.
To summarize,
- commuting on tarmac in all weather. Some slight hills. Can't use a fixie because of my knees.
- Towing a kid's trailer (Thule, attachment mechanism)
- Sportives?
What I want:
- drop bars--I like them better
- Hydraulic disc brakes--stopping power in the wet and low maintenance
- Hub gear or BB gear (like pinion)--less maintenance
- Belt drive or chain case--less maintenance
- Light weight: 15kg max--This is partly about handling and partly about getting it on and off of a bike hanger in my garage; I have a recent shoulder injury.
- Internal cable routing--Just because I like the clean lines.
- Narrow tyres--This is a road commuter, not a gravel bike.
