MacB
- Farnborough, Hampshire
Prices include UK postage, payment can be by paypal gift or bank tranx, or cash on collection, postage discounts for the latter or multiple items. Pictures:-
Overall sales bundle by MacBludgeon, on Flickr
http://www.flickr.com/photos/37729119@N08/
£820 posted or £720 collected -£850 posted or £810 collected - custom Burls 29er frame, almost unused, it certainly looks like it. Geometry - if you think Singular Swift or Salsa el Mariachi then you're very close. I'm 6'1" fairly standard proportionally. This was designed for rigid forks but with a mind to being able to run 80/100mm suspension forks as well. I suppose it could run 120mm forks but I think that would be pushing it. Frame - Burls custom Ti designed around 470mm AtoC forks(ie suspension corrected for 80mm), disc brake only, HT 130mm 72 degrees for standard external headsets, ST 34.9mm 508mm CtoTop and 452mm CtoC 40mm extension above TT and forward facing seatclamp slot, 73 degree angle. TT is 592.9mm actual, 620mm effective and has a 17.1 degree slope. BB shell is standard 68mm width, 60mm BB drop and has been faced. DT is oversized at 45mm. Chainstays are 445mm and S-bend style as are the seatstays. Full rack and guard mounts on frame. DT derailleur cable routing and TT/Seatstay brake cable routing, zip tie cable clamp style. All fittings have stainless steel socket head bolts in them greased, full CAD drawing supplied with all the details etc.
SOLD - £90 posted - Forward Components mini EBB for standard BB shells, this is the universal version and can be used with MTB or Road, Hollowtech II style cranks via use of 5mm spacer...for a 68mm shell only. Others have used it with a 73mm shell but either by dremelling off granny ring mounts or facing down the shell. It has very few miles, is in excellent working order and comes with all the instructions. I am quite happy to fit, or assist in fitting, for the purchaser....BB shell should be faced in advance of fitting. This can be used for Fixed Gear but a brake is recommended, ie no fixie skidders need apply
SOLD - £9 posted -£10 posted - Hope bolt up seatpost clamp, 34.9 in red, never used, I ordered an extra in error and can't remember where from and it's not in the little box.
SOLD - £6 posted -£7 posted - Hope bolt up seatpost clamp, 31.8 black, lightly used, there are no marks of any kind
SOLD - £35 posted -£50 posted - Homemade Super Compact chainset & BB, Tiagra Triple square taper cranks, 170mm silver, Stronglight 24t steel inner ring, Stronglight Zircal 40t middle ring, Thorn Alloy bashguard outer in black. Comes with crank bolts and UN54 113mm square taper BB for 68mm shell. Cranks are used but in ok shape, rings, bashguard and BB are immaculate and very low mileage. This worked well with a Sora double FD.
SOLD - £140 posted or £120 collected - 29er/touring Hope Pro II rear wheel, 36h black, on Mavic TN719 black disc only rim(stickers removed), has done a total of about 100 miles. Handbuilt by Big Al at Wheelcraft and with tandem spokes on the drive side, spokes are silver. This is a great wheel and very noisy freewheel, I have another identical but built with a red hub.
SOLD - £37 posted -£40 posted - SLX M660 9 speed trigger shifters with all cables, new and unopened
SOLD - £20 posted - SRAM PG950 road cassette, 9 speed 11-26, new and unopened
SOLD - £18 posted - SRAM PC991 9 speed chain, fitted to triple but then removed, 114 links and powerlink, plus a couple of spare powerlinks
SOLD - £65 posted - Tektro Auriga Comp hydraulic disc brakes with 160mm rotors. The brakes themselves are in good working order, they don't need bleeding and are fitted with new sintered pads from superstar components, I'll also include the spare set of unopened pads. The rotors are ok but probably need a little truing, I was going to get around to it honest. Front has 80cm of hose and rear 140cm, the levers have an open clamp design, oh and you get an instruction booklet as well.
SOLD - £6 posted - Superstar chain tensioner
SOLD - £6 posted -£7 posted - Superstar SS spacer kit in black with 20t cog and silver lockring, fitted but not used
SOLD - £9 posted -
SOLD - £6 posted -
SOLD - £35 posted -
SOLD - £37 posted -
SOLD - £6 posted -
