youngoldbloke
Where have they gone - editing, smilies insert link etc toolbars have disappeared?
Mine is OKWhere have they gone - editing, smilies insert link etc toolbars have disappeared?
I thought they used Javascript?On the laptop - can you see the text Use Rich Text Editor at the bottom of the editor window?
If so, click it and you should get the icons / toolbars back. If not, check you have java installed as they won't work without it.
Alternatively, if you have a different browser installed on the laptop, use that to test whether CC works as expected?
Cheers,
Shaun
Cheers,
Shaun
Press Alt, or right click IE anywhere on the top bar and click menu. After you do either of those, click Tools and look for Compatibility Mode Settings, then you can manually enter the site that is not working correctly and it should fix the problems for the sites that broke with this release.
Thanks Shaun, Cycle Chat was excluded, and I removed it, now all seems to be working again (smiley to prove it!)
