Loose cranks here's what to do.
Monkey wrench lock ring of without removing crank arms sit it on spindle for now open the cone (or is it the cup)do this with crank arms still on. Tighten everything back up by hand banging on the crank nuts occasionally.Once tightened as far as possible by hand tighten with monkey wrench back to what it was. ( take the caps of you will break them).
