long drop brakes?
zzpza
any one know what drop i would need to use 26" wheels in a 700c frame?
thanks! ;)
John the Monkey
Frivolous Cyclist
Crewe
Depends on the frame and the wheels - measure them up.
Guidance from Sheldon Brown's page here;
http://sheldonbrown.com/gloss_ra-e.html#reach
andrew_s
Gloucester
31.5mm more than whatever drop your 700c frame uses. ((622-559)/2)
Tektro R556 go up to 73mm and Alhongas up to 75mm, so you may be OK so long as your existing frame is a close clearance one (standard road calipers use a 39-49mm range).
zzpza
zzpza
thanks! there were no brakes on the frame when i got it, so i can't work it out from that. the frame's being powder coated at the moment, so i'll have to wait for it to come back to measure it.
