PpPete
- Chandler's Ford
The Weinman centre-pulls on this are not great...(as I found out today on a longer test ride)
Did a bit of research - found from Sheldon how to measure drop (about 65mm) , previous thread on here led me to Tektro R556
but there seem to be 2 models - nut fitting and allen key fitting.
The second option is cheaper - but says only for frames with allen key recesses - where on the frame? I'm guessing it will be the first and more expensive option given the age of bease, but I'd rather be sure so if anyone can shed light on this...
or any cheaper ways of improving braking performance ? Bearing in mind there are no cantilever bosses on frame or forks..
