Lock out suspension
lulubel
Malaga, Spain
Suspension forks aren't totally rigid, even when locked out. There will still be some movement in it.
With lock out the amount of movement will be just a few mm. Check out some other websites before you order, you'll probably get a better deal than halfords.
Eg chainreactioncycles etc...
02GF74
no idea what your bike is - sorry too lazy to google - but a couple of points to be aware of.
forks are abailable for 26 and 29 inch wheels - make sure you buy the correct one.
forks are availalble with tapered steerer i.e. the diameter of the steerer at the bottom is larger than at the top - you need to have corresponding bearing and head tube to fit it.
finally check the travel of the fork - it needs to be close to what your frame was designed for.
