Little help with buying a carbon stem please
Andrew_Culture
Internet Marketing bod
Hello all, my stem is freakishly long and I think it's part of the reason my hands are going numb after about an hour of cycling.
I have a budget of about £30 so thought I'd have a butchers on Ebay to see if that would buy me a carbon stem, on the basis that perhaps a carbon stem might help reduce road buzz.
I'd appreciate some help as this is an area I know nowt about.
Here's the list of stems on sale...
I was thinking of THIS Ritchey or THIS FSA.
My current stem is an alloy ITM.
Andrew_Culture
Andrew_Culture
[QUOTE 2339382, member: 259"]Have a look at Planet-X as well, they always have a few big bargains in stems and seatposts.[/quote]
Thanks, I always forget about Planet-X, THIS Deda stem looks interesting.
mattobrien
Sunny Suffolk
How long is your current stem and how much are you looking to shorten it by?
Weight wise you could 'afford' a heavier stem, by making sure you go for a wee before you start each ride - more than likely to offset any weight penalty of a heavier stem ;)
Andrew_Culture
Andrew_Culture
Get one of these lighter and cheaper than the Deda one you have linked to, It is not carbon either. :whistle:
I certainly like the price!
I think I'm put off carbon now, on account of the advantage being 'naff all' :smile:
90mm - are you a midget :tongue:
Heh heh. I'd go for alloy personally. Just be careful buying some stuff off ebay that is carbon, or indeed FAKE Ritchey/Deda/FSA. If it's too cheap, there usually is a reason.
Alloy stems are usually stiffer and weigh about the same. Road buzz can be reduced by bar tape, and indeed the bars.
tigger
At a guess that's either 120 or a 130. Not freakishly long by any stretch. If it helps, Wiggins rides a 140. The stem is the length you need to get the right fit. I wouldn't mess around unless you're sure you have too much reach. I doubt it makes your hands numb - tyre pressure, fork material, handlebar thickness, bar tape and your gloves will probably have a bigger bearing here.
Andrew_Culture
Andrew_Culture
Cheers, if there's an option not to save money I'll go with it :smile:
Looks like a 120. I ride 120 on the fixed and 130 on the road bikes. They also have a 2cm longer top tube.
Makes no difference to me. So check other issues out.
