Litespeed T5 series
139NI
I am looking to buy a Litespeed T5G gravel bike.
I have seen the T5G frameset only on wiggle being sold for £1800. http://www.wiggle.co.uk/Litespeed-t5g-flat-mount-di2-compatible-frameset-2016/
I have also seen at Evans, the Litespeed T5D Ultegra Road complete for £2659. https://www.evanscycles.com/litespeed-t5-ultegra-disc-2015-road-bike-EV236960
My question is:
Are the T5G and T5D frames identical? I would think the fork would be dissimilar as the T5G accommodates wider tyres.
Is the T5D the same as the the T5G but with a CX fork?
Does anyone know where I can pick up a complete T5G - cos that's the objective.. I would prefer not to buy the frame and components separately to build.
Cheers
W
Try fatbirds for all things titanium :smile:
StuAff
Silencing his legs regularly
Portsmouth
Will,
Short answer is no. The disc is more suited to sportive/endurance- different geometry, tighter tyre clearances (28mm I think), rear is QR not though- axle. T5G will take 40mm (possibly slightly wider depending on make and type), or 35mm with mudguards. Slacker geometry for better stability off-road, through- axles front and back.
I doubt Evans have any stock left. Wiggle are Litespeed's UK agent. If you really want one frameset may be your only option.
jowwy
Not here offten enough to argue
That does look decent- not quite the tyre clearance the T5G has, but it does have rack and mudguard mounts (T5g does have rack mounts but not for guards). Whether the build quality is anywhere near Litespeed's...pass.
They probably come from the same suppliers..........
