Linear dimensions.
Just been out to measure mine.
The frame is an “I” beam. It is 3” deep X 1 ½” wide. The top and bottom of the I are 1/8” proud of each side to allow for clamping on of components. The New York built Linears produced by Peter Stull may be different again, though he continued to use up older frame parts, with modifications, in the early 2000s, until he began to produce the re engineered models.
How long is the Linear wheelbase? Iowa Linears came in a range of frame sizes. According to the basic information sheet that came with mine:-
Inseam Measurement Recommended Frame Size
22"-26" = 36"
25"-29" =39"
28"-32" = 42"
31"-35" = 45"
34" & over = 48"
It goes on to say, "The LINEAR is very adjustable and can accommodate a wide range of individual sizes. (For example a person with a 28" inseam can fit on a 45" frame.)
How they worked out the different frame sizes I can only guess. The main beam on mine is just about 42" so it's feasible that that was the part that varied between different frame sizes. That would mean that there was a foot in length difference between the largest and smallest sizes, and maybe a choice of wheel sizes on the smallest ones. I have a photo of what is essentially an Iowa Linear titled “Linear Mach III” which has a welded frame and 20” rear, 16” front, wheels. The frame length will also affect the wheelbase which on mine is 65 1/2”.
Linears are very modifiable, for example the rear wheel for most will be 26", though mine came with a 700c rim built on to the Sachs 3 X 7 hub by the previous owner. It had a drum brake front wheel with a French standard 440 20" rim on it. Probably the original would have been a 451 20" rim, more common in the US, swapped for the sake of the drum brake. I've since swapped that for a 406 20" drum brake wheel, as the tyre choice is better.
Definitely not a "one size fits all" with the Linear. This is irrelevant for most British Linear buyers, as they would all be pretty much pre owned and you would buy whatever became available at the time. But it goes to show that Linear tried to make a tailor made product for their customers buying new. I could have ended up with a 48" frame, while a larger person might have ended up with a smaller frame, depending on how much of the range was imported into the UK in the 80s and 90s.
No doubt the steel vs aluminium debate rages on, but I certainly have no qualms about loading mine up and setting off on trips. It dates from around the mid 90s, I've had it for nearly four years now and have used it a lot, and it inspires faith.
Any other info or measurements needed, please ask.
