Lightweight tourer?
MyNameIsEarl
Hi all, I'm thinking of replacing my 2016 Genesis Equilibrium (25mm tyres, 50/34 front + 11/28 rear, rim brake, 9.5kg) and 1987 Raleigh Royal (14.5kg) with a lightweight tourer.
Can you recommend anything new (something from Spa, maybe), or would it be worth me converting the Genesis - with a stronger 32 spoke rear wheel and larger 11-40 cassette + Wolftooth & med cage derailleur? The chainstays are a bit short too and think I'd get heelstrike when loaded with panniers, but I think you can get extenders for rear racks.
I only tour one or twice a year, so I'm keen on using it the rest of the time as my main winter/all round bike. I also have a nice fast steel road bike for summer, and a fixed gear for all year riding.
Budget is around £2k, if buying new.
Thanks in advance!
All uphill
Still rolling along
Somerset
Spa would certainly provide you with a bike to meet your needs. I happily do light tours on my Spa Aubisque. The last few are now available at £975.
Would you consider touring with your Genesis using bike packing bags and the biggest tyres that will fit? An option would be to fit a 46/30 crankset to reduce the overall gearing.
The Equillibrium is an Audax style day tourer of the kind that many tourists use for a week or 2 of Euro touring.
Are you planning to camp or cook?
Heel strike depends on how much heel cutout your panniers have and how high they are, as well as crank length/show size.
Carradice saddlebags are a good option.
The modern doitall cx/ tourer/ fast commuter is a modern equiv to the Audax style but more versatile.
M
MyNameIsEarl
I'm happy to keep and upgrade the Equilibrium, as it's a great bike - so that's reassuring @MichaelW2 :smile: I've not camped, but will be doing so in the future (unlikely to need cooking stuff though), as it'll be just 1 or 2 weeks in France next year, with plenty of stops.
I've got 40litre Ortlieb panniers, which are really good, and so would be using those. The Raleigh has a chainstay lengh of 440mm and the Genesis is 420mm - hence my worry about heel strike. Current cranks are 172.5mm.
I have 28mm tyres on my Equilibrium and it makes longer rides easier.
With the large ortleib panniers and camping load, a day tourer with shorter chainstays may get a bit rear heavy and " tippy".
You need to test the load and put as much weight within the wheelbase or up front.
geocycle
I’d recommend a Spa elan for winter rides and light touring, especially if you’ve got a light summer bike already. The elan is ultra smooth and will comfortably take 38 mm tyres. Prices are £1500 to £3000 depending on spec. I have one set up for winter rides with wide tyres, mudguards, disk brakes, dynamo lights and capacity for light touring and light off-road. I find the Spa audax more fun for dry day riding in summer on tarmac.
Gunk
Oxford
Thanks in advance!
Have a look at Oxford Bike Works in Steventon
