Light chain oil in large containers?
Shut Up Legs
Down Under Member
Hi,
As the thread title suggests, I want to find a source for some light chain oil in large containers. I'm fed up with buying chain oil in silly little containers that don't last long enough. I prefer the light (i.e. low-viscosity) oil, even though I have to apply it more often.
Any recommendations?
For the 1,000,000th time, LINKY :thumbsup:
It's even an Oz link for you as well mate :becool:
mrandmrspoves
Middle aged bald git.
Narfuk
Chain saw oil is good - but I still have 5 litres of semi synthetic 5/30 engine oil left over from my last car. If I upgrade my trike to a faster model, I might have to upgrade the oil to fully synthetic - which is fine because that's what my current car uses! (To be honest, I think my current trike has the capabilities to be much faster - but the current engine's (me) power to weight ratio is far too low)
mrandmrspoves
Narfuk
Oil for cars is designed to work at engine temperatures would be effective at room temperature?
It works absolutely fine. Engine oil is designed to withstand great extremes of temperature - but it has to work when the engine is cold too. Using engine oil for a bicycle (tricycle in my case) is very much a case of overkill - but a lot of cyclists drive too and probably have a good supply of engine oil - but spend unnecessary cash on an inferior product that claims to be bike specific.
Shut Up Legs
Shut Up Legs
Down Under Member
Which is exactly why I'm looking for alternatives. Thanks for the replies, people, I really appreciate it. Cyclechat comes up with the goods, as usual :thumbsup:.
youngoldbloke
I run 3 bikes regularly, I use around 4oz Progold Prolink a year. Just about to order 16 oz pack from Evans - £15.29 - should last me getting on for 4 years = £3.83 a year = about 7.5p per week ......... there are lots of other things I could economize on before having to cut down on this extravagant indulgence!
Drago
The Urban Fringe
I use 70 weight synthetic gear oil. It's relatively cheap, clingy (technical term that), and is more than up to managing the pressures involved. I'm a bit anal about chain cleaning, but my chains last as long as they ever did with the branded cycle chain ungents.
Shut Up Legs
Shut Up Legs
Down Under Member
Well, I seem to go through them faster than that, perhaps it's the distance I cover in a year.
youngoldbloke
Maybe. I'm very sparing with application - use a hypodermic needle, just one drop per roller. I aim to do around 5K miles in a year.
