Lezyne lights and aero seat post combo
Yazzoo
Suffolk
Anyone got this combo?
I just bought a set (macro front, micro rear) largely on a recommendation and also because of the rubber strap fitting rather than fixed plastic as my frame is quite angular. The front is on the bars fine, the rear I'm not so sure about. It's currently on my seat post. The shape of the plastic bracket is for a circular post although the rubber strap does appear to hold the light in position whilst stationary.
Without the obvious 'go for a bumpy ride and see if it's still there when you get home' I wondered if anyone else had this set up and was confident that the strap held it securely despite the bracket not fitting, or if they had modified theres at all for a better fit?
Also, will my garmin charger lead work? They look the same but I'm reluctant to try it, but that said if each light takes 6hrs to charge i'm keen to do both at the same time!
Joffey
Big Dosser
Yorkshire
All a Garmin charger is a micro-USB - if the Lezyne lights charge with a micro-USB I would say yes, it will work!
Yazzoo
Yazzoo
Suffolk
Ah!
I'd only plugged in the front (macro) with the wire when I wrote the post, just opened the little rear one and theres no mini usb port as there is with the front, it just plugs straight in the usb port on computer!
Bugger, bought the lights off a Facebook cycling group, not wiggle etc, so didn't see there was an aero specific model - d'oh!
