Lezyne HP Drive Pump
wheres_my_beard
Norwich
Anyone else using one of these > ? http://www.wiggle.co.uk/lezyne-hp-drive-pump-2011/
I bought one yesterday, and it seems well made and all that, but I can't get the hose to connect properly onto the valve.
When I went to pump my tyres up to a nice high pressure in a park and I failed miserably, and ended up with a softer tyre than when I started!
If I thread it all the way down, which feels like a snug fit, i doesn't inflated, but if I thread just onto the first threaded part of the valve, it inflates but then works itself free straight away.
I can't see anything with it, but it is not as straight forward a fit as any other pump I've used with a hose connector.
Anyone else had this problem??
GrumpyGregry
Here for rides.
what valves are on your tyres and are you matching the right end of the hose to the relevant hose type?
wheres_my_beard
wheres_my_beard
Norwich
I have Presta valves and the other end of the hose is Shrader; I would have a totally flat tyre if I tried to connect that end!
This is what is baffling me. I didn't expect to have to experiment to find the optimum connection, but I guess I'll have to. Bah.
deptfordmarmoset
Full time tea drinker
Armonmy Way
I don't know the adapter but it did find a while ago that if my hose wasn't completely straight the unscrewed Presta valve could foul the valve head and screw itself shut again as I attached the adapter. Or at least that's what I thought was happening.... But making sure it goes on cleanly (valve either at the top or the bottom of the wheel) seems to have cured it.
buddha
I have a different Lezyne pump, but with a similar, screw-on head. And have found that backing-off half a turn, or so (after screwing the head all the way down) works for me.
Had to use the thing for the first time in over a year, this Friday.
