This is how I am currently setup, thanks. I appreciate that this is how you want them to feel, just wondered if there was a starting point.I just set it up so the brake pad is just rubbing, then back off the barrel adjuster a bit. So as close as poss to the rim without rubbing. However, bear in mind that I am a clueless idiot, so this is probably very bad practice.
Yep that makes a lot of sense. I'm going to fit the lights and see how it feel tonight.I have mine set to about half way through the stroke..so i have more leverage so more power as my grip gets nearer to a fist..my personal preference.
if that makes sense..
That sounds like a good method, I will give that a go.There's a lot of personal preference and intended use (road or trail) plus the technical limitation of the trueness of the rim.
If I am fitting a new cable or blocks I set each block up so that it makes correct contact with the rim, then wind out the adjuster barrel to at least half way.
Pull the cable through the clamp until the blocks are touching the rim and tighten the clamp.
I can then screw in the adjuster until the blocks rest at the postion I want.
I find this helpful for when I only have two hands or my third hand tool can't be maneuvered into a workable position.
