left side gear change
s7ephanie
middle of nowhere in France
Its really hard to turn the left hand handle to change the front gears, is this normal or am i just a weak, limp wristed girl !!!!!
trying to do more on the big wheel (cog ?) but by time i have managed to turn thre thing i have come to a hill and itd too late !
deptfordmarmoset
Full time tea drinker
Armonmy Way
A squirt of WD-40 or light oil might loosen it up.
Chris S
Birmingham
I had the same problem changing to the big front cog as you when I had an MTB. The secret is to do it at before you slow down, which means reading the road ahead.
Glasgow
Yes Steph, wiping gear cables with an oiled (lubed?) cloth helps smooth gear changing.
Also quirt some spray lube on the front derailleur from time to time (I do when I wash the bike) watch not to get any on the rims, or if you do clean it after.
I find easing quite a bit on the pedals when you change front gear helpful.
It is true that once you are on the big ring a hill promptly appears lol!
dasy2k1
Member
Whenever I relube my chain, the cloth I use to wipe off the excess gets wiped over all the exposed inners of my brake and gear cables, chain lube seems to work great on cables
