Last week my lad said he was having difficulty changing onto the big ring on the crank set, he asked me if I would have a look, so I adjusted the gears and got it changing ok, I said it was probably a bit of cable stretch.
This morning he again was having difficulty, then his left crank fell off it must have been coming loose last week allowing the crank set to move out a little this was causing the bad shifting.
Its a Shimano 105 crank with the two bolt fixing and the plastic end plug that pulls the crank into position.
Has anybody else experienced this?
I can only think it hasn't been fitted correctly to start with.
Its a Giant TCR which he purchased from Tredz.
