Clean the area as best you can then operate the lever several times and watch for where fresh fluid is coming from.
Who serviced it last time then?Cross threaded top bolt.
New shifter almost £200 !!!
Wouldn't mind but it's not even 12 speed. !!!
They should pay.,
Don't ask don't get."Should"
But in practice I doubt you get any where with such claims.
Set the bolt in with some epoxy resin. Fil it with fluid first and fit new pads then you should get at least two sets of pads worth of miles out of it.A few wraps of PTFE (or gas fitters tape) might get a good enough seal and bite to keep you going while to source a new one.
