Lap Top Video card help
Willow
Surrey
how do I establish what is installed. I am relatively computer literate but can't find this piece of info. given that it is about 5 years old I am wondering if it is possible it won't have one. Have upgraded memory but am wondering whether I need to do something with VC.
Carwash
Señor Member
Visby
It's not under 'Display adapters' in the Device Manager then?
Carwash
Señor Member
Visby
Willow said:
SiS650 comes up there is that it, doesn't say anything about Video Card
That's the one. Google informs me that it's integrated graphics, i.e. part of your motherboard, not a separate graphics card. So good luck doing anything with it in a laptop case.
W
Willow
Surrey
marinyork said:
Unless I'm very much mistaken that is absolutely ancient.
I'm sure it is it's an old lap top from work which I have bought home at no cost for one of my boys. So next question is can I do anything about it? virtual tennis for instance needs ATI Radeon 9600 or higher/Nvidia Geforce FX5900 or higher. the laptop is absolutely fine for internet, and microsoft applications but I am sure given the chance he may like to play the odd game.
marinyork
Resting in suspended Animation
Logopolis
Virtual or Virtua? I ask because Virtua tennis is a fairly famous game. I've played it and the information you want is probably out there.
W
Willow
Surrey
You're right it's virtua. I guess it's possible when I get the additional memory card to put in it might play it?
mr Mag00
rising member
Deepest Dorset
do try the driver upgrade for starters
Peter
Adding memory will not make a difference - it's the video card that needs to be up to date and those quoted above are more powerfull than your existing one. Also if the graphics card is built into the motherboard you will not be able to upgrade:sad:
marinyork
Logopolis
Yes. Do upgrade the drivers.
Unfortunately it won't be possible to upgrade the graphics on that laptop.
Virtua Tennis the original I have no doubt will run on that system, I have the hunch you are talking about virtua tennis 3. The cards it talks about in the minimum specs are old but it needs directX 9.0c which along with only 64Mb shared is the problem.
W
Willow
Surrey
Great thanks, for your help folks. I thought that would be the case, given that it was free I have no complaints. We have an old chessmaster that I am sure will run on it and as has been said there are one or two fun things on the net. The rest of the time he'll be doing HOMEWORK:biggrin::biggrin:,
marinyork
Logopolis
There are plenty of games (that are slightly older) that will run on that system Willow, just not virtua tennis 3 unfortunately. So if you get hold of some white titles, classics or second hand games some of them should run fine.
