WindyRob
- On the doorstep to the Southdowns
just brought some new Ksyrium Equipe wheels. I swapped over the 9 speed block from my old wheels and tightened everything and went for a ride. The rear cassette didn't seem to be running smoothly. When I got home i discovered that the locking nut on the cassette was tight up against the hub to the required torque setting but the cassette was still loose and able to move by about 1mm. I took it all apart and on close inspection the hub is longer than the depth of the cassette.
Any thoughts? I'll go back to the shop in the morning to discuss with them; but i would like to go armed with some knowledge in case they try to baffle me with bull! It's the first time i have used this LBS so not sure what they are like.
Thanks
Windy
Thanks
Windy
