Knowledge about plaster
Fastpedaller
I've been doing some plastering of our Daughter's house. One thing that struck me....... All the plaster is just specified as 'gypsum'. I've used bonding plaster (very useful for deep areas eg if filling a chasing), multifinish (seems an odd name) and finishing plaster. The finishing plaster can only be used to about 2mm thick, the bonding plaster can go to 11mm thick - but they are both described as gypsum! Can anyone shed any light on what's different in the make-up between these two plasters?
Cycleops
Accra, Ghana
From doing a bit many years ago I seem to remember the bonding plaster was rather coarser than the finishing plaster which was finer. That's all really.
newts
Isca Dumnoniorum
Bonding/hardwall plaster is an undercoat, an alternative to sand & cement undercoat. It is a thicker coat(s) to smooth the wall from a rough brick/stone substrate. Finish plaster is the top coat that is smooth & harder, finer particles. Multifinish is just a finish plaster that is suitable for most undercoats gypsum, plasterboard & sand/cement etc.
newts
Isca Dumnoniorum
Spoken like a pro @newts .
Not a pro plasterer, but I've been working within the building industry for 40+ years😉
F
Fastpedaller
Thanks - I'd worked all that out, but it's still unclear what's in the different products which are all simple described as 'gypsum'. Particularly why for example one can be layered up to 11 thick without cracking and an other will crack if more than 2mm?
newts
Isca Dumnoniorum
Gypsum based undercoat dries quicker than cement based renders, allowing the finish plaster to be applied much sooner. Gypsum bonding/undercoat plaster will also contain a good % of larger particle size to allow for thicker coats without slumping or cracking. A bit like the difference between mortar & concrete.
Cycleops
Accra, Ghana
You might all be interested to know that plaster is unavailable here apart from plasterboard and PoP. which is used for all decorative ceiling work with fibre. All wall rendering , in and out, is done with sand & cement.
F
Fastpedaller
Ah!, so are the ingredients the same for both bonding and finishing plaster, but larger particle size in the bonding is key to avoiding cracking and slumping?
