Thomk
- Warwickshire
I need a new chain for my Charge Mixer 2010. It uses a KMC X9 chain and there appears to be a choice between a KMC X9 73 and a KMC X9 93. What is the difference?
About £4I need a new chain for my Charge Mixer 2010. It uses a KMC X9 chain and there appears to be a choice between a KMC X9 73 and a KMC X9 93. What is the difference?
I also have a Mixer - 2010. Save your dosh and fit an X8 73 / 93 chain.
8 speeds chains are stronger and cheaper than 9 speed. I replaced the stock chain when it wore out with an 8 speed and it works flawlessly.
What benefit does Nickel coating give, considering the metallic plates of the chain don't actually wear noticeably and the pins between links are the wear-point?
this a dodgy advice, a 9-speed chain is slightly narrower than an 8-speed version - it might still work but not a good idea!
The Mixer is an 8-speed hub geared bike. The usual advice about chain compatability does not matter here - the OP could run a (even cheaper) single speed chain if he likes.
I run an 8sp chain because one of my other bikes is 3 x 8 derailleur set up, so I just buy a pack of chains that can be used on multiple bikes
so what is the precise thickness of the sprocket used on this set-up?
