just degreaser or not
jimboalee
Solihull
Here we go again :rofl:;)
4F
Suffolk.
jayce said:
Ill just buy the degreaser at lbs and do it my self
Jayce. There are many methods you can try and you will get just as many supporters either way.
Personally I clean my chain with baby wipes and lube otherwise known as "the mickle method" which does the job with the least hassle.
I have in the past used a chain cleaner with white spirits and also a 2 litre coke bottle with de-greaser.
Use the search on "the mickle method"
J
jayce
south wales
That sounds fine to me baby wipes it is got finish dry lube so im off to give it a go ,cheers fella:biggrin:
J
jayce
south wales
i just found some loctite activator from one of my old jobs and i use it to clean the bearings in my fishing reels i gets them gleeming its very good stuff so il clean the chain with that then dry lube it
