Lovacott
Hi all,
Just bought a Nean front and rear light and although there is cable to connect the Dynamo to the front light, there is no cable supplied to run from the front (master) light to the rear (slave) light?
Both front and rear lights have two spades each which are supposed to couple them up as a pair (the dynamo power goes to the front first via the supplied cable and the rear light slaves off of it).
But with no cable supplied, how are you supposed to do it?
I could go out and buy some twin core cable and solder it to to the spades at each end, but I would have thought that there would be a proprietary cable available with push on connectors at each end to make connection (and removal) a lot easier? I've hunted high and low on Neans website, Amazon, Ebay etc. but to no avail.
Help!!
Help!!
