Jump to last read post button - Not Working
summerdays
Cycling in the sun
Bristol
If you press the little button to the left of the thread title - you expect it to go to the first un-read post in a thread ... currently its taking me straight to the first post.
fimm
Edinburgh
This is happening for me, too.
summerdays
summerdays
Cycling in the sun
Bristol
Well ... strangely its gone back to working normally again .... it certainly still wasn't working half an hour ago ...
I'm on Google Chrome...
summerdays
summerdays
Cycling in the sun
Bristol
Err - no its not working properly ... I think on threads I have already looked at this morning it is jumping to the right place (hence the previous post saying it was working) but on threads that I looked at yesterday (in some cases replied to), it goes to the first post. Its rather frustrating having to try and work out which was the last post I read especially when it is over several pages.
fimm
Edinburgh
I'm on IE7 and I think what has actually happened is that my browsing history has been deleted, so the system has "forgotten" where I've read to on threads older than this morning. I'm seeing the same effect as Summerdays.
Shaun
Founder
Same for me too - I had masses of unread threads when I logged in a few moments ago.
It looks like the thread marking history has failed or disappeared.
I'll put a support ticket in with IPS.
Cheers,
Shaun
Scoosh
Velocouchiste
Edinburgh
Cheers,
Shaun
Is this a first ???
Something goes wonky with CC ....
.... and it's not been Shaun 'tweeking'/ fiddling ??? :biggrin:
[Font sizes are playing up a bit too]
Shaun
Founder
Why thank you ... I aim to please ... :biggrin:
Anyway, I've rebuild the internal caches - let me know if things improve?
Cheers,
Shaun :biggrin:
MacB
Cheers,
Shaun :biggrin:
Everything seems to be back to normal barring the own post bit, where it is still showing stuff as new that isn't. Not a problem though, it was the same when it all changed over and faded away quickly...or at least it did for people like me that post and read a lot.
Shaun
Founder
If you've read up to date and want to clear all the "old" read markers, you can use the link (upper right) on the forums, or the global "Mark Board As Read" marker at the bottom left.
After that, it should maintain the markers again.
Cheers,
Shaun :biggrin:
