Juddering Rear Mech
Noted a new noise at the rear so I went through the process of re indexing my gears to make them smooth.
I have indexed my gears many times. When I am in the largest cog at the back and smallest at the front my rear mech judders up and down, not a lot but enough not to right. I have used the screws to change the reach of the mech with no joy, re indexed, checked cable tension.....
What else do I need to try to make it smooth again?
Cheers Mr P
rusky
CC Addict
Hove
Is the chain or cassette worn?
Tynan
e4
what rusky hints at?
something not running well in those gears is transmitting the tension to the spring in the rear mech, so maybe not the rear mech
potsy
Rambler
My Armchair
Cheers Mr P
why would u use the smallest chain ring and the smalest rear? the chain is at extreams then ?
Re-read required steve
ianrauk
Tattooed Beat Messiah
Rides Ti2
I don't think the chain or cassette is worn. But do agree with GA, check the b tension screw to lower the derallieur a little.
Mista Preston
Mista Preston
just spent the past hour trying the screws again. No joy. Is their anything else I can try?, could the mech have moved or something?, may need to go to the LBS
Has The rear mech hanger taken a bash? How does the mech alignment look to the eye in lowest gear?
