Rhythm Thief
- Ross on Wye
I'm currently running my Mercian with Campag 9 speed. Everything is Campagnolo except the rear cassette, as the rear wheel has a Shimano freehub. With this in mind I did a bit of research and found the Jtek Shiftmate, which is apparently designed to match Campagnolo shifters and derailleurs to Shimano cassettes by changing the cable pull ratio. Fabulous.
So I bought one (and they're not cheap!) and fitted it according to the instructions, including turning the pulley around. And here's the thing... The shifting was immediately much, much worse, to the point where if either extreme of the cassette worked, the middle was unusable, with the chain constantly jumping between two cogs. I've just ridden home from work, avoiding certain gears, and taken the thing off because the shifting is better without it. These things get good reviews (and it's nicely made) and I'm not new to setting indexed gears by any means, but am I doing something wrong here or has anyone else had issues with these things?
