Jammed rear Tiagra gear cable
grellboy
Evening my lovelies! Crashed a while back and replaced various parts. Now got round to replacing rear gear cable but it seems jammed in hood: can't push through or pull out. Not particularly helpful pictures attached. Any help appreciated.
Slioch
York
What I'd do is to cut the gear cable leaving about an inch or so, then do some serious jiggling about.
grellboy
grellboy
On smallest cog already. Did think about cutting it down and leaving it be? But not sure that's the best idea.
U
User6179
If it has been trapped in the mechanism and providing it is similiar to 5700 and 6700 shifters you can loosen the bolt that holds the mechanism together, it is located underneath the shifter, you have to remove the clamp that holds it to the handlebars to reach it.
grellboy
grellboy
It's 2016 Tiagra, which is the newer style, rather than old loopy cable type. Will have a fiddle and hope everything doesn't fall apart.
U
User6179
Just dont loosen the bolt completly, it wont fall apart but the nut is inside the shifter and hard to get back on the bolt, you pull the brake lever as far as possible and the nut is located in the opening betwween the lever and top of shifter, the bolts used to unwind on the 6700 shifter and the nut would fall out causing the shifter to jam, took me an hour just to get the nut back in place so be carefull
Deleted member 35268
I have the exact same issue!!!!!!!!!!!!!!!!!!
The manual...
https://si.shimano.com/pdfs/dm/DM-ST0002-05-ENG.pdf
