Ozzrahog
- Tyne & Wear
Having got my new road bike up and running its time to let my MTB find a new home, from its current one in Washington Tyne & Wear
For sale a Jamis Trail X3 Mountain Bike (2012) 19 inch frame £200
This is a very well looked after, excellent condition mountain bike, which is less than a year old. It will make an excellent commuter or first mountain bike. The Trail X3 is proof positive that trickle-down technology is a good thing. Just a few years ago, the Enduro III frame would’ve been state of the art with its oversize, ovalized, tapered 6061 aluminum tubing, radically sloping top tube and trussed seat tube. In fact, it bears more than a passing resemblance to the Jamis Dakota dXC bike, with a frame that’s lightweight and strong, backed by proven geometry and killer parts spec. It was upgradedd for 2012 with a 34.9mm seat tube and 31.6mm seat post for a firmer, more efficient pedaling platform.
The Trail X3 offers a slightly more upright riding position than our other mountain bikes to help relieve strain on neck and back, and give you a taller perch for see-over-traffic perspective on city forays. And the handling’s tweaked for a bit more stability, which helps you thread your way through the trail with confidence.
The tyres have been upgraded to Schwalbe City Jets which offer unrivalled puncture protection and a semi slick tread offer lower rolling resistance than traditional knobbly tyres.
I have also added Raleigh peddles with toe clips (the original flat pedals are unused and included with the bike) as well as front and rear mudguards
The right hand grear shift/brake lever mech was replaced in Feb this year at my local bike shop
The only significant paint work damage is from cable rubbing on the left side of the head stock (please see picture)
Collection only, payment in cash at collection
Full spec
Frame
Enduro III frame design, 6061 aluminum main tubes, radiused top tube, over-sized seat tube, extended seat mast with brace, replaceable derailleur hanger
Fork
RST Blaze TNL, MCU/coil spring with Turn-n-Lock lock-out and external preload adjustor, 100mm travel
Headset
VP threadless, 1 1/8”
Wheels
Alex TD-25 double-wall rims, powder coated, 32H, alloy 6-bolt disc hubs with QR, 14g black stainless steel spokes
Derailleurs
Shimano Acera M360 rear and Acera M310 34.9mm top pull front
Shiftlevers
Shimano Acera ST-EF51 EZ-Fire Plus, 24-speed
Chain
KMC HG40
Cassette
Shimano CS-HG30, 8-speed, 11-32T
Crankset
Shimano M361, alloy crank arms, 42/32/22 rings, 170mm
BB Set
Sealed cartridge, 68 x 122.5mm
Brakeset
Tektro mechanical disc brakes with 6” rotors and Shimano levers
Handlebar
Jamis XC riser, 6º sweep x 13mm rise x 620mm
Stem
Jamis XC alloy threadless, 10º rise x 90mm (13-15”), 100mm (17”), 110mm (19”) and 120mm (21”)
Grips
Kraton for trigger-shift
Seat Post
Jamis OS alloy micro-adjust, 31.6 x 350mm with alloy QR clamp
Saddle
Jamis ATB with pressure relief channel, SL cover, protective front and rear guards
Size
19”
Color
Pearl White
Weight
32.00 lb
Full spec
Frame
Fork
Headset
Wheels
Derailleurs
Shiftlevers
Chain
KMC HG40
Cassette
Crankset
BB Set
Brakeset
Handlebar
Stem
Grips
Seat Post
Saddle
Size
19”
Color
Pearl White
Weight
32.00 lb
