My neighbour's niece's husband thinks I know a bit about bikes , so asked me to have a look at one he bought recently.
Nice badge - and name !
I love the 'Made like a Gun' part below the cannon ...
Frame number, I think, under seat:
In all it's glory:
... and the drive side:
Interesting that the gear shifter is under the control of the stoker , whose handlebars are attached to the rear of the driver's seat, so bar height is dependent on driver's leg length.
There's a bit of work to be done, so I'll probably be seeking advice but I have a start list:
Any comments, suggestions and other advice of an encouraging nature welcomed !
In all it's glory:
- rear tyre, tube, rim tape all shot
- rear wheel might be true but some of the (mainly drive-side) spokes are very slack - virtually loose
- oil cap on rear hub missing ... so what could be inside ?
- rear hub bearings make 'interesting' sounds ...
- rear drum brake works - but will certainly need checked
- need to find the equivalent of the High and Low stops on the gears, though might just be done by cable tension ...
- front wheel/tyre seem useable but drum brakes need checking/adjusting
- not too sure about the mudguard colour either ...
