Shortandcrisp
Replacing the headset bearings on a Caad 10. Unfortunately the outer casing of the lowest bearing is seized solid in the aluminium frame and won’t budge. I suspect a winter of sweat on the turbo has added to the problem. I’ve tried applying heat and gallons of WD40 to no avail. I’ve also tried to ‘chisel’ it free from above, but the retaining ridge in the headset makes it difficult to access the bearing.
Any suggestions?
Any suggestions?
