Monsieur Remings
- Yatton UK
Okay, have been busy doing a bit of fettling on the old Giant with a view to it being, well a bike to fettle around with and learn a bit more as I go along. Last night I figured the rear caliper needed some serious attention with a bit of rust at the point it bolts to the stays. I unscrewed the bolt and released the cable . This was enough, with the rear wheel removed to have a right go at the caliper which I did. However, when I came to replacing the cable, there seemed to be no tension on the brake lever. Worse still after fiddling I realised that when I achieved tension on the lever the caliper was seizing up and not expaning back out after contracting (probably the wrong terms).
So, I took the bugger to the bike shop and they suggested taking it apart completely and greasing it up. Problem is, some of the little hex key bits keep wrecking my hex keys and just won't budge. So, I noticed a massive amount of crunt inside the calipers so used hot water and bike cleaner to spray it off. I've since GT-80ed the whole lot and left it in the sun with the intention of adding some grease as best I can when it's dry.
Any other suggestions or do I need a new caliper?
