Isla bikes jumping gears
The_Hawk
Member
South Wales
Hello,
First post and not sure whether to post here or maintenance.
My daughter's Isla bikes seems to jump out of gear 7 and 8. She changes up however, it seems not to engage properly.
Just wondered if easy fix or should I take to a proper shop
Thanks
screenman
Rear mech alignment?
Cycleops
Accra, Ghana
As above, unless you want to try it yourself. Its probably the limit screws gone out of adjustment possibly cause by the cable gone slack. You'll only need a cross head screwdriver and there are plenty of bids on YouTube. Might be an idea to remove the cable and grease it too.
T
The_Hawk
Member
South Wales
Quick update - Isla say the rear hanger has been damaged. It doesn't look that bent at all to me. Would a slight bend really make that much difference?
screenman
Well it is the first thing I check anytime I am adjusting or setting up gears. Which is why I suggested it, I have never once checked a year mech that cannot be tweaked.
keithmac
7 and 8 is small cog rear sprocket?.
You could possibly remove and straighten the hanger then reset limit screw and cable.
To be fair if you've got kids it pays to be hands on with bike maintenance!.
keithmac
You would be lucky to straighten it correctly without the tool to check it with.
Just thought of this thread, my son came in with his mountain bike after apparently using it as a goalpost.
Derailleur jamming into wheel in 1st and he was quite upset he'd broken his bike..
In 10 minutes I'd removed derailleur pivot, straightend derailleur hanger by eye using an adjusable spanner, reset his top and bottom limit screws and adjusted his cable.
No special tools in sight just bit of common sense..
keithmac
It was quite nice really as I explained on how all his gears worked and he took it all in, don't think we've had his bike upside down and gone through all the gears before now!.
screenman
It really is worth buying an alignment tool, by eye is often a long way out as you only check it one way.
keithmac
I looked down from the top to make sure it wasn't scewed, looked from the back to make sure it was in vertical alignment (hanger and derailleur cage) and made sure chain tracked properly in all gears.
I had to pull hanger straight both ways and twist his derailleur cage as it had been belted with a football.
In 33 years of using an fixing pushbikes I've never needed an alignment tool but not knocking anyone who uses one..
screenman
I went 40 years without needing one, I have now used it on a lot of bikes and not found one that does not need tweeking, honestly borrow one and give it a try. If you were close you would be welcome here.
