BigonaBianchi
Yes I can, Yes I am, Yes I did...Repeat.
- Iskele TRNC & Mordor UK
The rear mech changes fine going down the cogs (smallest to largest) but going the other way( largest to smallest) it skips a lot and randomly, mostly missing 3 or 4 cogs and landing on the smallest cog. I've cleaned the cassette and chain and re lubes etc. I've sprayed gt85 into the cable outers as much as i can and into the shifter an dunder the bottom bracket. I've re tensioned the cable but no matter what i do it just keeps slipping.
The cassette had a larger biggest ring fitted in an attempt to make hills a touch easier without resorting to a triple. I dont know the ratios, but the LBS did it before the LEJOG a few months back.
Ive got a new cable but am loathe to take all the bar tape off if it's not likely a cable issue.
Thanks
Thanks
ok...i did all that and then I replaced the cable anyway just in case, even though I saw no kinks or fraying. I re tensioned the cable and the same thing is happening. Major rear end slippage...hmm...i spent nearl 3 hours fiddling with it...the bike i mean...so tomorrow it's back to th eLBS of great expense and much umming and arring...
