Is my headset faulty?
I just got a new Token CADAC x headset to go with some new forks. I had a play about with them in the LBS and particularly looked at how the bottom sealed bearings seated on the crown race which was a good flush connection. When I got it home and installed the crown race I slipped the bottom cup on to see how it fitted and it is no longer flush at all. No matter how I twist the cup it the steerer always is slightly closer to one inner edge of the cup and the bearings don't seem to sit properly.
I don't want to install the cups on my frame on the off chance this misalignment will cause a problem and I'm not sure the LBS will even accept it as a return as the race has already been installed.
Anyone else experienced such an issue if it actually is one?
A quick glance suggests 30 and 45 degree bearings.
Have you got the top bearing on the bottom?
Ignore this
B
Bailsofhay
Member
They came in the cups and I never took them out. I just put them in situ exactly as they came out of the box .
The only thing I can think of is that the bearing is not seated in the cup correctly. Does it look to be level?
B
Bailsofhay
Member
I've been told I may not have seated the race quite flush so i'm gonna get the Lbs to give it a few whacks with a proper tool and see if that helps.
Cheers for the help!!
B
Bailsofhay
Member
Sorry accountantpete I hadn't seen your post when I wrote that but I recon your right on the money. I just used a piece of PVC pipe to put it on so I'm thinking it must be out .5mm I just cant get it right.
cheers!
