jon the student
Is my bike worth fixing? Will it be easy? NOW WITH PICS
Hello everyone,
Firstly may I apologise to John the Monkey and others for awful student cycling nationwide! (I used the search).
Ok, now that's done, my name's jon and i'm a student. I've just started cycling this term (see sig) as money is tight because of the other item in my sig(!). I also wanted to take up cycling because I used to swim a lot but after a shoulder injury and subsequent lack of any time (Engineering degree) I no longer have a vice with which to keep fit. So I've got the bike out and started using it.
Unfortunately, it is quite old. Probably 15 years I'd guess. It's my older bro's hand me down, and has had a long and full life. To show its age, it has Shimano Altus C10 gears (trigger change ones) and they're pretty worn now.
Basically, I had some issues with the freewheel I think ( to be honest, if it doesn't have an engine, I'm not very good) because the crank would free-pedal backwards which is normal, but also forwards about a quarter turn. Also, the chain would jump massively if I ever tried to properly get some speed on - I've spoken to some people and they think the chain is stretched/loose and is jumping off some teeth when pedalling hard. Because of the chain issue, I've resigned to using the top 7 gears which aren't actually that bad, bit slow from start but fine after that. Also my derailleurs are all over the shop. The rear one works fine, but the front rubs on the chain when in use (has been realigned with new cable recently) and sometimes pushes the chain allll the way down to the bottom 7, leaving me pedalling away and not going very far. Oh, and if I just stand the bike up and backpedal it quickly by hand, the chain gets stuck after a few seconds as if it's stuck between gears?
Overall, I think the crankset is worn causing the chain to jump, the freewheel (same thing as the cassette?) is dying as it doesn't take up forward slack well, the derailleurs are past their best and one of the seat springs squeaks. Is this ticking all the right boxes on the New Bike Justification List?
I'm happy to do the work myself, strip it to a frame and rebuild it all up but realistically is it going to be more economic to just buy a new bike?
Thanks for reading this far, it's a bit of an essay.
Jon :-)
Hello everyone,
Jon :-)
