Panter
Just call me Chris...
- Sittingbourne, Kent
A couple of Years ago I serviced the hubs on a rear wheel (Bontrager, cup and cone)
Had no idea what I was doing, but was assured that it was an easy job, just unscrew the nuts, clean the bearings, re-grease and off you go.
Which, to be fair, it was.
But, ever since, I've had a strange problem that the rear brake would keep rubbing the rotor. It was an easy fix (avid caliper) just re-align it and all would be well. Until the next ride where it would need doing again.
It's a real nuisance, the wheel doesn't spin freely at all, but it's just something I've put up with. Also, the inside pad wears down faster than the outside.
Anyway, I've just watched an online video of how to service a hub, and it's quite specific about which side of the axle you undo.
Could I have reassembled the thing with the axle too far to one side, hence the constant rubbing on the brake pad?
If so, is it possible to realign the axle to where it should sit by eye?
