DSK
I have been using the track pump below since last summer, very regularly. Bought it from Amazon as it had 4.5 stars over some 1650 reviews.
I only use the presta valve, and despite using it to check tyre pressures and adjust regularly, today it was not to be. Woke up at 5:30am to get out for my daily ride, went to adjust the tyres pressures and anything above 80 psi and the pump valve head just hissed Its never done this so I made several attempts at re-doing it on both wheels with no luck. After 15 minutes I was totalled (So i resorted to the mini pump and guessed the pressure, only to find on the ride it was quite a bit lower than 100psi which is my norm.)
So can the head of such a pump wear out? If so, how long long do such pumps typically last?
