Is it possible for a Shimano 3 speed front mech. to work on a compact 2 chain ring ?
Doug.
Hello.
Re. above, building another cycle from the bits I have available.
The 3 speed front mech. will it work on a compact chain ring crank ( 2 CHAIN RING ) ?
If not will I have to buy A 2 SPEED MECH ?
Thank you for any replies.
arch684
Yes it will work.just use the limit screws to stop the chain traveling to far
Doug.
Thank you for the replies, very much appreciated.
tissot, you mention the limit screws may be different, could you please explain .
Best wishes and regards to you all.
Your front mec is for a triple the front mec for a double will/may have different length limit screws
the triple mec has to drop lower to hit the smallest chain ring .
