02GF74
I have an Atala tremila 3000 aluminium road frame with carbon rear stays that needs an integrated headset.
Meaurements:
41.3 mm (top) 41.6 (bottom) mm diameter in head tube
than then has an angle - not measured that. (looks like 45 degree)
depth 7 mm
steerer race 30.1 mm
so will this fit? <---- linky
Note the markings on the race - it seems to correspond well to my measurements although the 41.0 mm is smaller than the hole it is meant to go in.
So do you thihnk it will fit? Not been able to find out spec. of the headset for the bike. I suppose for £ 15 worth a punt?
And what is difference between semi-integrated and integrated?
Meaurements:
depth 7 mm
