Installing Ubuntu with Boot Camp on OSX 10.5
Melvil
...I'm having kittens trying to install it. Every time I partition my drive and then run the CD, the boot camp utility says 'no boot disk found' or something to that effect.
Any tips?
alecstilleyedye
nothing in moderation
use parallels instead and run it inside the mac os.
HJ
Cycling in Scotland
Auld Reekie
I am no expert on Macs but if you down load the Ubuntu Pocket Guide there are instructions on page 17 on how to install Ubuntu with Boot Camp.
Apparently you create a 5GB (or bigger) partition then when Boot Camp Assistant finishes shrinking the OS X partition, hit the QUIT & INSTALL LATER button.
Delete the NTFS (Windows) partition created by Boot Camp Assistant.
Download and install the rEFIt software. This provides a boot menu that lets you choose between Mac OS X and Ubuntu. rEFIt can be downloaded from http://refit.sourceforge.net— choose the Mac disk image download. NB There is no immediate sign that rEFIt is installed.
Insert the Ubuntu install CD and reboot your computer. when you hear the boot chime, hold down the C key. Eventually, you’ll see the Ubuntu install disc boot menu. Follow the instructions on screen, but when the partitioning stage begins, don’t resize. Instead, select Guided- Use the Largest Continuous Free Space. (There is a bug with Ubuntu 8.10 when selecting the Guided‐Use the Largest Continuous Free Space option shows Ubuntu occupying the entire disk in the “After” graphical preview. This wrong and can be ignored.)
Follow through the installation stages, as if installing on a normal computer. When you reboot, select the Linux penguin on the rEFIt boot menu to boot Ubuntu, or the Apple icon to boot OS X (use the cursor keys to highlight either, and hit Enter to select).
Hope that helps.
Yellow Fang
Reading
This is interesting. There was an article in a magazine called 'Switch to Mac!', although it's talking about running windows. There's a guide on how to configure boot camp, use VMWARE Fusion, and use Parallels Desktop for Mac. It recommends using virtualisation in preference to boot camp, as you can run both operating systems in parallel and drag and drop files between them. It said that you could actually configure your Mac so that you could have both a boot camp partition and virtualisation, by setting up Fusion or Parallels to use your boot camp partition as the source for the virtual machine. Both Parallels Desktop for Mac and VMFusion cost about £50, but the magazine says there are free emulators available, such as VirtualBox (www.virtualbox.org). I can't find where I read it, but I'm sure it said this all applies to Linux distros too.
