Installing new bar tape
plastic_cyclist
Angus
Is it wise to take this task on oneself or would it be better served to take it to a LBS ?
I was going to follow this tutorial....
Tape Guide
Also is it a good time to replace hood covers as these are looking a bit faded ?
Any other tasks which are common to do whilst doing this?
figbat
Slippery scientist
I was hesitant but had a go - turned out really well. It’s easy to undo and redo if you need to, but with a bit of patience it should go fine.
  • Like
Reactions: DSK
slowmotion
Quite dreadful
lost somewhere
I watched dozens of clips on YouTube. All the hipsters from US bike shops talked at lightning speed and were hard to follow. In the end I found a UK one and set my laptop next to the bike playing the tricky bit (round the hoods) in slowmotion. I made a hash of it but they lasted a few years.
You can always peel the stuff off and have another stab at it. Good luck.
biggs682
Northamptonshire
Tape Guide
Have a go just don't ask the question about do you start at the end ie drops or in the middle as that always ends in people getting angry
Broadside
Fleet, Hants
If you’ve got under tape gear or brake cables then check or replace them at the same time but it’s not something that needs to be done often.
Definitely have a go yourself, the first couple of times may not be perfect but it is really satisfying when you get the knack. I always buy my kids second hand bikes and replacing the bar tape is often one of the first things I change. I’ve saved a small fortune learning to do it myself!
Brandane
Costa Clyde
It's an easy enough job to do, but as with most things - when buying bar tape, you get what you pay for. Cheap tape means it might be easy to tear when fitting, and if you do make a hash of it then undoing the bit you messed up and re-doing it might not be pretty. I've settled on using Cinelli cork tape on all my bikes. It's easy to fit and very comfortable on the hands once fitted. If you do need to un-roll it after fitting (changing cables etc.) then it can be done easily without ruining the tape.
Middle every time :rolleyes:
rovers1875
Accrington
Just have a go, it's not difficult. Take your time and try to keep the wrap even. If not confident get a cheap roll of insulating tape and a bit of tubing and practice, so becomes second nature.
Getting the overlap right takes a bit of practice, as does the wrap around the levers but it isn't rocket surgery and you (by which I mean me) can always unwrap and try again.
rogerzilla
Reminds me, I need to do the yellow Harry Quinn. I found some NOS Cateye shiny tape that just about matches the paint. It'll look sick, as the kids say.
