I am having my first go at installing a Shimano 600 1" threaded headset after having a steel frame powder coated.  Two questions for you fettling experts please:
1. I have got the crown race on using a spare extension tube from a vacuum cleaner. On one side I can see a 0.5mm gap and on the other there is no gap at all. I didn't think to clean it before I started so it has been a bit of a brute to fit. Do I carry on hitting the side that is proud or is this level of gap likely to be a result of slightly uneven coating/a variance that doesn't matter?
2. I am in the course of fitting the lower headset cup, which is getting close to the frame. I am using a length of threaded rod, an indented washer (a part from IKEA that lets you use one of the larger European lampshades with a narrower light fitting) and some washers and nuts. However the cup too is not quite level. The variation is 0.75mm so that one side is 0.5mm away from the frame and the other is about 1.25 mm away. Do I (a) carry on and let it right itself when it gets flush with the frame, (b) tap the rod and if so in which direction (I am feeling a bit spatially challenged or (c) install the other cup and hope the first cup rights itself in the process.
Here are a couple of photos.
I am veering towards leaving problem 1 and pressing on with the second cup but would appreciate any thoughts/words of comfort before I swallow my pride and head off for the LBS.
Many thanks in advance.
